[Qgis-developer] URL Rewriting and qgis-web-client
Andreas Neumann
a.neumann at carto.net
Tue Feb 26 08:03:32 PST 2013
You always have to specify a project path and project name with QGIS web
client. Regardless whether you use URL rewriting or not. The client does
not work without project path and name.
So a correct URL to start the client would be:
http://hostname/maps/projectpath/projectname?optionalParameters
Of course this all depends on your setup.
This whole URL rewriting is a bit complex to set up. Before you do it I
would recommend you test the client without URL rewriting, e.g. with a
URL like:
http://hostname/qgiswebclient.html?map=/home/web/qgis-web-client/projects/naturalearth_110million.qgs&format=image/png&visibleLayers=Rivers,Glaciated%20Areas,Lakes,Land,Ocean
For 'var serverAndCGI = "http://THE_HOST/wms/"' I recommend to not
specify the servername, in case you move the whole thing to another
server. Better would be:
var serverAndCGI = "/wms/"
Hope this helps a bit?
Andreas
Am 26.02.2013 16:33, schrieb Emilio Loi:
> Hi everybody, I hope you can help me.
> I'm trying to enable URL Rewriting in Qgis-web-client as described at point
> 5 of the configuration guide (https://github.com/qgis/qgis-web-client)
> I'm using this rule:
> RewriteRule wms/([^/]+)$
> cgi-bin/qgis_mapserv.fcgi?map=/var/www/qgis-web-client/projects/$1.qgs
> It works well: when I browse http://THE_HOST/wms/example on firefox the
> server returns the cgi script result whit parameter
> map=/var/www/.../example.qgs
> Then I've set
> in GlobalOptions.js instead of the full url.
> The problem shows up when Qgis-web-client trys to use the cgi script:
> instead of call /wms/example/?params it calls /wms/NOTHING/?params. (as you
> can see)
> [16:09:20.950] GET
> http://THE_HOST/wms//?&_dc=1361891360854&SERVICE=WMS&VERSION=1.3&REQUEST=GetProjectSettings[HTTP/1.1
> 404 Not Found 126ms]
> What am I forgetting to configure?
> Thanks in advance.
> Qgis-developer mailing list
