[Qgis-developer] URL Rewriting and qgis-web-client
Andreas Neumann
a.neumann at carto.net
Tue Feb 26 08:41:21 PST 2013
If you do the redirects, I recommend to always do two redirects:
* one for the WMS
* one for the HTML/JSS/CSS files
Here is what I use (modified to hide my paths):
#Rewrite Rules for QGIS webclient
# Map /wms to qgis_mapserv.fcgi
RewriteEngine On
RewriteLog /var/log/apache2/webgis_rewrite.log
RewriteLogLevel 0
#handle WMS requests to QGIS server
RewriteRule ^/wms/(.+)$
/cgi-bin/qgis_mapserv.fcgi?map=/www/projects/$1.qgs [QSA,PT,L]
# Map /maps to /qgis-web-client
# First handle the mapping of the starting html file - works for 1 to 7
levels
RewriteRule ^/maps/([^/.]+/{0,1}){1,7}$
/qgis-web-client/qgiswebclient.html [PT,L]
Hope this helps?
Andreas
Am 26.02.2013 17:32, schrieb Emilio Loi:
> Thanks for your answer.
> First, I'd corrected serverAndCGI value.
> Without any redirect rule all works perfectly.
> Currently I have only one RedirectRule that redirects any
> */wms/project*request to
> *qgis_mapserv.fcgi* script),
> <Directory /var/www/qgis-web-client/site/>
> Options Indexes FollowSymLinks MultiViews
> AllowOverride all
> Order allow,deny
> allow from all
> RewriteEngine On
> RewriteRule wms/([^/]+)$
> http://vega.faunalia.it/cgi-bin/qgis_mapserv.fcgi?map=/var/www/qgis-web-client/projects/$1.qgs[QSA,L]
> </Directory>
> so I access to QGIS web client at this url (the actual one):
> http://vega.faunalia.it/qgis-web-client/site/qgiswebclient.html?map=/var/www/qgis-web-client/projects/candela.qgs
> Is it correct? It has full project path with project name in *map* request
> parameter.
> Bye,
> 2013/2/26 Andreas Neumann <a.neumann at carto.net>
>> Hi,
>> You always have to specify a project path and project name with QGIS web
>> client. Regardless whether you use URL rewriting or not. The client does
>> not work without project path and name.
>> So a correct URL to start the client would be:
>> http://hostname/maps/projectpath/projectname?optionalParameters
>> Of course this all depends on your setup.
>> This whole URL rewriting is a bit complex to set up. Before you do it I
>> would recommend you test the client without URL rewriting, e.g. with a
>> URL like:
>> http://hostname/qgiswebclient.html?map=/home/web/qgis-web-client/projects/naturalearth_110million.qgs&format=image/png&visibleLayers=Rivers,Glaciated%20Areas,Lakes,Land,Ocean
>> For 'var serverAndCGI = "http://THE_HOST/wms/"' I recommend to not
>> specify the servername, in case you move the whole thing to another
>> server. Better would be:
>> var serverAndCGI = "/wms/"
>> Hope this helps a bit?
>> Andreas
>> Am 26.02.2013 16:33, schrieb Emilio Loi:
>>> Hi everybody, I hope you can help me.
>>> I'm trying to enable URL Rewriting in Qgis-web-client as described at
>> point
>>> 5 of the configuration guide (https://github.com/qgis/qgis-web-client)
>>> I'm using this rule:
>>> It works well: when I browse http://THE_HOST/wms/example on firefox the
>>> server returns the cgi script result whit parameter
>>> map=/var/www/.../example.qgs
>>> Then I've set
>>> in GlobalOptions.js instead of the full url.
>>> The problem shows up when Qgis-web-client trys to use the cgi script:
>>> instead of call /wms/example/?params it calls /wms/NOTHING/?params. (as
>> you
>>> can see)
>>> [16:09:20.950] GET
>> http://THE_HOST/wms//?&_dc=1361891360854&SERVICE=WMS&VERSION=1.3&REQUEST=GetProjectSettings[HTTP/1.1
>>> 404 Not Found 126ms]
>>> What am I forgetting to configure?
>>> Thanks in advance.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
