[Qgis-developer] non integer ID and python
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Feb 26 22:27:49 PST 2013
Hi all,
I have a small problem in my quickfinder plugin (finds a feature by its id).
For postgis layers, I have no problem to find a feature using its id.
But, I can't achieve this with shapefiles for example.
I understand this as the IDs of shapefiles are store in strings.
Apparently, in the SIP of QgsFeature, QgsFeatureId is defined as a qint64.
Also, in the SIP of QgsFeatureRequest, the setFilterFid method takes
qint64 as argument.
So my question, is there a way to look for a feature by its ID in python
if it's not an int???
And if not, do you consider it easily changeable??? How?
Thanks a lot!
Denis
