[Qgis-developer] Uploading plugin
Rudi von Staden
rudivs at gmail.com
Wed Feb 27 07:52:35 PST 2013
I think my Distribution Map Generator plugin (
https://github.com/rudivs/DistroMap) is at a stage where it can be added to
the plugin registry for those who would find it useful. I tried doing so
via http://plugins.qgis.org/plugins/add/, but it gave the following error:
Error 500: internal application error.
An email message with all error details has been sent to our staff that
will fix the issue ASAP.
I'm not sure if I'm adding it in the wrong place, or if I should try again
later? I set up the framework using Plugin Builder, so is the included
'plugin_upload.py' script the recommended way to share the plugin?
Thanks,
Rudi
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130227/92f66427/attachment.html>
