[Qgis-developer] New OpenStreetMap integration
Borys Jurgiel
lists at borysjurgiel.pl
Thu Feb 28 14:37:24 PST 2013
Wow, great!
Unfortunately seems it doesn't work with Wheezy's Spatialite 3.0.0. Tomorrow
I'll try to compile a newer version and test it.
Anyway, it would be nice to have it in Debian working out of the box. Maybe
updating the very outdated internal Spatialite (what is its current status and
purposes?) would solve the problem?
B.
Dnia czwartek, 28 lutego 2013 o 22:35:33 Martin Dobias napisał(a):
> Hi all
> so finally I have pushed my initial work on OpenStreetMap integration
> to master... d'oh I have missed The Open Data Day (Feb 23) by few
> days! The idea is to completely replace the current OpenStreetMap
> provider and plugin. As announced in the list before, the new OSM
> support is read-only and right now I have no plans to add editing
> functionality. Editing would mean a _lot_ of work - map tools,
> tracking of changes, conflict resolution - and there are already great
> programs for editing OSM data.
> If you would like to test the new stuff, go to menu Vector >
> OpenStreetMap. No need to enable any plugins. The workflow should be:
> 0. get OSM XML file (from web or download in GUI)
> 1. import XML file to a SQLite topology database (once)
> 2. export SpatiaLite layers from topology with a fixed set of tags -
> attributes
> Integrated download uses Overpass API, so you should be able to
> download data from any extent size. The download server in GUI is
> currently fixed to overpass-api.de. When using download, make sure to
> set high timeout (Options > Network > Timeout for network requests) -
> currently there's a problem with QGIS network manager - it will time
> out after the fixed time even if the data is being continuously
> received.
> The work is by no means complete, there are various pieces missing,
> though it should be already usable. Some features I would like to add:
> - advanced download queries (e.g. filtering by tags)
> - filtering on export (e.g. export only railroads, only restaurants)
> - python bindings
> - support for relations
> - identification GUI (e.g. see all tags, even those not exported)
> There is a low-level API in qgis analysis library which should allow
> 3rd party tools/plugins do some work with OSM data (currently
> QgsOSMDownload, QgsOSMXmlImport and QgsOSMDatabase classes).
> Please let me know what do you think about it or if you encounter any bugs.
> I will be removing the OSM provider+plugin very soon. This is another
> piece from the master plan for removal of old symbology (OSM provider
> implements a renderer based on old symbology).
> Martin
> Qgis-developer mailing list
