[Qgis-developer] Better options dialogs
Larry Shaffer larrys at dakotacarto.com
Fri Jan 4 09:47:34 PST 2013
Hi Matthias and Nathan,
I was just about to bring this topic back up myself. :^) Yes, I can
work on this next (probably this weekend). I'll start with the main
app options dialog, cause it's the simplest.
Option dialog candidates to switch to vertical tabs (for
useability/consistency):
* App options
* Project options
* Vector and Raster layer properties
Matthias, do you think the new diagram options setup can be moved to
horizontal tabs, instead of a toolbox, once there are vertical tabs
for the vector dialog?
Nathan,
> ...  If you need some help I can lend a hand.
Remember that little custom toolbutton widget we chatted about for
data defined option overrides? (to the right of labeling options in
redesign [0]) I think you mentioned some kind of abstracted data
binding class that widgets like that could use or inherit. Such a
class, that worked with the new vector API, would be very handy and
greatly help with the labeling dialog redesign (and elsewhere). Do you
have some time to work on that?
See http://irclogs.geoapt.com/qgis/%23qgis.2012-11-26.log starting at (14:44:28)
[0] http://drive.dakotacarto.com/qgis/labeling-redesign.png
Regards,
Larry
On Fri, Jan 4, 2013 at 7:12 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Larry,
> If you do have time for this I too would really like to see this added. The
> tabs situation is becoming a mess and is only going to get worse as we move
> forward.  If you need some help I can lend a hand.
> - Nathan
> On Fri, Jan 4, 2013 at 5:51 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
>> Hi Larry,
>> What is the status of the vertical tabs? Do you still have a branch with
>> them ready?
>> I noticed, that the new labelling dialog in the vector layer settings has
>> two columns of tabs, which look a bit uncommon, and I'd see vertical tabs as
>> a good replacement for either the first or the second level of tabs in this
>> dialog.
>> Cheers,
>> Matthias
>> On 09/05/2012 09:10 PM, Larry Shaffer wrote:
>>> Hi,
>>> I've been working on reducing overall clutter and excess space, and
>>> trying to increase efficiency and extensibility, with options dialogs.
>>> Problems with current option dialogs' parent QTabWidget approach:
>>> * Tab widget uses unnecessary vertical space (bad for small screens).
>>> * Tab widget limits the use of reasonably needed tabs for option
>>> sections (avoiding tabs-within-tabs unfortunately trumps useability).
>>> * Horizontal parent tabs limit how many option sections can be offered
>>> (already too wide, without text truncation, on Mac).
>>> * Horizontal parent tabs dictate the width of the dialog, causing form
>>> layout elements to optically stretch too far apart.
>>> Possible solution: Move 'tabs' to simple list widget on left side of a
>>> splitter and have option sections loaded on right.
>>> I have done mockups for the app and vector layer options [0], which
>>> show the following advantages:
>>> * Vertical height is maximized without sacrificing layout of option
>>> section form elements (good for smaller screens).
>>> * Number of option sections is not graphically limited.
>>> * Number of option sections no longer dictates width of option section
>>> forms (forms look much better).
>>> * List item widget can have its splitter section collapsed to a set
>>> size to show only icons for sections.
>>> * Consistent look across platforms, with larger icons for sections.
>>> * More current 'look' for v 2.0 without too much work.
>>> Other than making the dialogs clearer and less cluttered IMHO, the
>>> full useability of the dialogs at smaller sizes helps the user see
>>> more map canvas when testing options with Apply.
>>> Any comments or suggestions?
>>> [0]
>>> https://www.dropbox.com/sh/yy0j3mmg4l4kw7x/Ar_S-eYqCv/qgis/options-dlgs?lst
>>> Regards,
>>> Larry
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
