[Qgis-developer] Additional settings for Print Composer Map item Grid
Andreas Neumann
a.neumann at carto.net
Mon Jan 7 00:42:40 PST 2013
To report bugs you first need to create a OSGEO user id at
http://www.osgeo.org/osgeo_userid and then create a new issue at
http://hub.qgis.org/ - it is not very hard. In your case you would open
a feature issue, not a bug issue. Of course it would be good to first
search in the existing bugs and feature request to avoid duplicate bugs.
Hope this helps,
Andreas
On Mon, 7 Jan 2013 00:29:55 -0800 (PST), Miro wrote:
> Ad 1 - oh, I don't have current master, good to know it is already
> in, hooray
> Ad 2 - ok, I will add it there (if I figure out how :-))
> Thank you
> http://osgeo-org.1560.n6.nabble.com/Additional-settings-for-Print-Composer-Map-item-Grid-tp5025847p5025887.html
> Sent from the Quantum GIS - Developer mailing list archive at
> Nabble.com.
> Qgis-developer mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
