[Qgis-developer] QgsColorButton
Werner Macho werner.macho at gmail.com
Mon Jan 7 08:15:15 PST 2013
OK - Then I was wrong with my guess .. :)
@Martin .. is V2 a better implementation or is it ok to stick with the
original code? Just because most people prefer to use the original code
does not mean that they should not use V2 if it is better ..
 But I see you already voted for removing V2
anyway - what about implementation into the Widget?
kind regards
Werner
On Mon, Jan 7, 2013 at 4:52 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> On Mon, Jan 7, 2013 at 4:44 PM, Werner Macho <werner.macho at gmail.com>
> wrote:
> > Having nothing to do with the code I'd vote for removing QgsColorButton
> and
> > letting the V2 do all the work (sounds newer to me - probably the
> original
> > is only used by old dialogues)
> Actually QgsColorButtonV2 was my experiment with a different look of
> the button. But it seemed that most people prefer the original one
> (QgsColorButton). I have been just too lazy until now to remove V2. In
> any case +1 to remove it.
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130107/4cb5d42d/attachment.html>
