[Qgis-developer] Attribute Editor: Dual View
Bernhard Ströbl
bernhard.stroebl at jena.de
Wed Jan 9 22:39:34 PST 2013
Hi Matthias,
comments below.
Am 09.01.2013 16:41, schrieb Matthias Kuhn:
> Hi Bernhard
> On 01/09/2013 03:07 PM, Bernhard Ströbl wrote:
>> Hi Matthias (and others),
>> I read your paper and I like the idea of the dual view because
>> currently it is not possible to open the attribute editor from the
>> table. On the other hand I am not convinced of the filter/selection
>> proposal. IMHO one of the strengths when using GIS data is the unity
>> of geometry and attribute data. Currently selecting a feature in the
>> map also selects its attributes in the corresponding table and vice
>> versa.
>> examples:
>> 1) Select in map and investigate attributes: If a filter was applied
>> the data might not be visible in the table without clicking "selection
>> to filter".
>> 2) filter logical in table and investigate these features in the map:
>> You would need an additional "filter to selection" button to handle this.
>> 3) field calculator: will it update the selected or the filtered
>> datasets?
>> I think the whole concept will confuse average users. I would favour
>> to keep the well established solution of features being selected no
>> matter where (table or map) the selection was performed.
> I think the reasoning for the change in the selection/filter paradigm
> was rather poor in the document itself. There are other reasons which
> are in favor of a change of filter/selection as well.
> E.g. If you want to manually select features out of different subsets.
> Let's say you have a layer with a lot of features and you're looking for
> a couple of cities (but not all of them) which have more than 100'000
> inhabitants and some others which do not meet this criterion, but some
> other criteria. At the moment, you can do this by sorting and scrolling
> and maybe some other tricks, but it's not that easy. With the
> independent filters, this would be a task of changing the filter and
> Ctrl-Clicking the required features out of each subset.
I see the point in this, but the case you describe could be solved
differently (that is at least theroretically :-). If the selection tool
would not always create a new selection (as is now) but enable the user
to either "add to selection" or "select within current selection" or
even "remove from selection" this would IMHO be more straightforward for
users.
Bernhard
> Nevertheless, I see your point as well. Manually picking some of the
> features on the canvas and then investigating them in the table sounds
> like a reasonable requirement and should not be forgotten.
> So maybe the button "show only selected" should still be kept available
> (and link selection and filters, as it does now) and live side-by-side
> with the new solution (while disabling some of the super-fluent widgets).
> Matthias
>> my 2 cents
>> Bernhard
>> Am 09.01.2013 12:43, schrieb Nathan Woodrow:
>>> Hey Matthias,
>>> Interesting idea. Look forward to seeing the development of this
>>> feature.
>>> Two questions before I ask any others.
>>> - Does this change the behaviour of the identify tool? What happens when
>>> I am in edit mode and click on a feature? Same as it currently is? If we
>>> could add multi edit, multi select to the identify tool that would be
>>> neat.
>>> - How would you handle custom UI forms? Just embed them in the split
>>> view.
>>> Overall I think it's a great idea and would greatly welcome a feature
>>> like
>>> this.
>>> - Nathan
>>> On Wed, Jan 9, 2013 at 6:44 PM, Matthias Kuhn<matthias.kuhn at gmx.ch>
>>> wrote:
>>>> Dear list,
>>>> Denis, Andreas and I have been working on a proposal concerning the
>>>> attribute table and attribute editor.
>>>> We are convinced that it is a good idea to combine these two into a
>>>> single
>>>> window and add/change some functionality.
>>>> There is a document [1] online which describes our ideas and
>>>> contains some
>>>> mockups. We will start working on this soon and would like to encourage
>>>> everybody to read and comment on our ideas.
>>>> Regards,
>>>> Matthias
>>>> [1]:
>>>> https://docs.google.com/**document/d/**1dL965ky4OoyeN9fEcqP9SWHVeQxTj
>>>> **1IFkBrEXTUBZuY/edit?pli=1#**heading=h.seeehmi30hq0<https://docs.google.com/document/d/1dL965ky4OoyeN9fEcqP9SWHVeQxTj1IFkBrEXTUBZuY/edit?pli=1#heading=h.seeehmi30hq0>
>>>> ______________________________**_________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
