[Qgis-developer] Attribute Editor: Dual View
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Jan 10 05:07:12 PST 2013
Matthias,
I try to do it with your words...
Am 10.01.2013 13:18, schrieb Matthias Kuhn:
> Bernhard,
> On 01/10/2013 07:39 AM, Bernhard Ströbl wrote:
>> Hi Matthias,
>> comments below.
> same here
>> Am 09.01.2013 16:41, schrieb Matthias Kuhn:
>>> Hi Bernhard
>>> On 01/09/2013 03:07 PM, Bernhard Ströbl wrote:
>>>> Hi Matthias (and others),
>>>> I read your paper and I like the idea of the dual view because
>>>> currently it is not possible to open the attribute editor from the
>>>> table. On the other hand I am not convinced of the filter/selection
>>>> proposal. IMHO one of the strengths when using GIS data is the unity
>>>> of geometry and attribute data. Currently selecting a feature in the
>>>> map also selects its attributes in the corresponding table and vice
>>>> versa.
>>>> examples:
>>>> 1) Select in map and investigate attributes: If a filter was applied
>>>> the data might not be visible in the table without clicking "selection
>>>> to filter".
>>>> 2) filter logical in table and investigate these features in the map:
>>>> You would need an additional "filter to selection" button to handle
>>>> this.
>>>> 3) field calculator: will it update the selected or the filtered
>>>> datasets?
>>>> I think the whole concept will confuse average users. I would favour
>>>> to keep the well established solution of features being selected no
>>>> matter where (table or map) the selection was performed.
>>> I think the reasoning for the change in the selection/filter paradigm
>>> was rather poor in the document itself. There are other reasons which
>>> are in favor of a change of filter/selection as well.
>>> E.g. If you want to manually select features out of different subsets.
>>> Let's say you have a layer with a lot of features and you're looking for
>>> a couple of cities (but not all of them) which have more than 100'000
>>> inhabitants and some others which do not meet this criterion, but some
>>> other criteria. At the moment, you can do this by sorting and scrolling
>>> and maybe some other tricks, but it's not that easy. With the
>>> independent filters, this would be a task of changing the filter and
>>> Ctrl-Clicking the required features out of each subset.
>> I see the point in this, but the case you describe could be solved
>> differently (that is at least theroretically :-). If the selection
>> tool would not always create a new selection (as is now) but enable
>> the user to either "add to selection" or "select within current
>> selection" or even "remove from selection" this would IMHO be more
>> straightforward for users.
> I'm sorry, I'm not able to follow this description exactly. Could you
> please describe in detail how you imagine the process.
> If possible, please also outline the scenario, where the user wants to
> check/update individually the attributes for all cities with more than
> 100'000 inhabitants in the attribute view.
"E.g. If you want to manually select features out of different subsets.
inhabitants"
in extended selection enter: num_inhabitants > 100000
click: "new selection"
result (example): 150 datasets selected
"and some others which do not meet this criterion, but some
other criteria."
in extended selection enter: some_other_field = some_other_ctriteria
click: "add to selection"
result (example): 270 datasets selected (150 from before + 120 matching
"some_other_criteria")
after that you can manually remove all datasets that you do not need
from the selection but I doubt this is a real use case, because how
would you decide which to keep and which to remove? Obviously because
some attributes match certain criteria, so here we go: e.g. user wants
to see only the cities with an airport
in extended selection enter: airport = false
click: "remove from selection"
result (example): 205 datasets selected (from the previosuly selected 65
do not have an airport and are therefore removed from the selection)
now have a look at the map and see where these cities are, in this case
manual removal seems imaginable, so lets remove 7 from the selection;
result: 198 datasets selected (205 - 7) in both table and map!
now the user can do anything with this selection (update certain fields,
export to new dataset, use for a spatial query...)
I am of course totally aware that the 205 datasets can be achieved by
using only one query like "(num_inhabitants > 100000 OR some_other_field
= some_other_ctriteria) AND airport = true" but the whole thing starts
getting interesting when we imagine a spatial query in the start e.g.
"select all cities within 20 km from the sea" then we could got to the
attribute table enter "(num_inhabitants <= 100000 OR some_other_field !=
some_other_ctriteria) AND airport = false" and click "remove from
selection" to get a result containing all cities with either more than
100000 inhabitants or some_other_ctriteria and an airport and within 20
km of the sea
the "show only selected" checkbox should of course work as one would
expect it to i.e. whenever the selection changes, no matter if this
change originates from a user's click in the table or map or from using
one of the selection buttons the dataset shown contains _all_ currently
selected datasets and _only_ them
I cannot imagine any use case that can not be tackled with what I
propose but I have a feeling that the filter/selection concept would
really confuse users
> Please excuse my ignorance
hope I could clarify what I mean
Bernhard
