[Qgis-developer] QGIS, Python and Threads
Kelly Thomas
kelly.thomas at hotmail.com.au
Tue Jan 22 19:07:25 PST 2013
Hi Matthias,
I had a similar problem a couple of weeks back. While I was unable to identify why my first attempt was failing I was able to produce a functioning implementation on the second attempt.
I posted my problem (and later a working solution) over here. [1]
Another gotcha to be aware of is that any python errors that occur in the other thread will be displayed in the Message Log, I find it useful to have this as a floating window during development.
[1] http://gis.stackexchange.com/questions/45514/how-do-i-maintain-a-resposive-gui-using-qthread-with-pyqgis
Good Luck,Kelly Thomas
> Date: Tue, 22 Jan 2013 10:33:16 +0100
> From: kaotika at gmx.de
> Hello,
> I try to write a plugin in python. The plugin will be part of a complex plugin and will make a longer running numpy> calculation. I want the GUI to be responsive during the calculation. As a basis I used Aaron > Racicots(http://svn.reprojected.com/qgisplugins/trunk/threading_demo/) threading example and modified the run code (the > calculation is only an example). Unfortunately it does not what I want it to do...it hangs during calculation. Did I missed a >thing?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130123/f960265e/attachment.html>
