[Qgis-developer] Python skipping features for unknown reason
Allar Haav
allar.haav at gmail.com
Wed Jan 23 07:53:46 PST 2013
Alright, set up a GitHub account:
https://github.com/haav/python/tree/master/PointAdjust
I have to stress that it is really work in progress though.
It works by putting in 2 feature ID-s (A and B) with needed coordinates.
The point A position is fixed and will be exactly as entered, but for
point B the resulting position may differ in order to maintain the
similarity. Thus, the new position of point A is used for translation
while point B coordinates are only used to get the rotation angle. So,
let's say we have the original layer points A=(0;0) and B=(3;0) and the
entered values for the plugin are A=(-3;2), B=(-1;4). Thus the rotation
angle will be 45 degrees.
Ah, right, the "edit mode" has to be turned on to get any effect.
Allar
On 23/01/2013 15:14, Nathan Woodrow wrote:
> Allar,
> We will have to see some code to be of any help. Why not consider
> putting it up on GitHub if you haven't already
> -Nathan
> On 24 Jan 2013 01:09, "Allar Haav" <allar.haav at gmail.com
> <mailto:allar.haav at gmail.com>> wrote:
> Hi all,
> I recently started learning Python and I'm currently finishing my
> first plugin that I really needed for QGIS - it performs a simple
> similarity transform on point layer. While the familiar qgsAffine
> presupposes that I know exactly the translation and rotation
> parameters, there often cases when I do not. What I might have is
> just information (GPS measurements for example) that points A and
> B should have coordinates x1,y1 and x2,y2. And that's it.
> So far I've managed to get everything working, but I have run into
> weird problems. When I perform the operations on really small
> datasets, everything is working fine. But when I have a layer
> with, say 600 points, QGIS starts acting weird. Sometimes it
> performs ok, yet once in a while some points aren't affected by
> the transformation, basically it starts skipping features. It
> seems as if the memory buffer is overloaded (?). Any ideas on
> that? The code in main transformation method is put between
> beginEditCommand() and endEditCommand(), the points are moved
> using moveVertex() function.
> Regards,
> Allar
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130123/074e6fda/attachment.html>
