[Qgis-developer] QFontMetrics problem in composer
Chris Crook
ccrook at linz.govt.nz
Sun Jan 27 11:36:01 PST 2013
Hi All
I'm working on a plugin which adds a custom plugin layer to the map. This all works fine on the desktop, but goes horribly wrong in print composer and in printed outout.
What it comes down to is that I'm using QFontMetricsF to calculate the size of some text, which I'm then using for layout. On the screen this is fine. In the printed output the rectangle returned by QFontMetricsF is about 1/3 the size of the printed text, which makes the layout pretty awful! The test code I have is as follows:
painter.save()
painter.setPen(QPen())
painter.setBrush(Qt.NoBrush)
painter.translate(position.x(),position.y())
painter.scale(fontFactor,fontFactor)
painter.setFont(font)
painter.drawText(QPointF(0.0,0.0),text)
painter.drawRect(QFontMetricsF(font).boundingRect(text))
painter.restore()
The result (after printing to PDF) is that the box printed by drawRect is about 1/3 the size of the text printed by drawText. This seems to be independent of the size and location of the map in print composer or the font used. Also printing to PDF or PNG gives the same result.
At first sight this looks to me like a bug in Qt, but that seems unlikely? Any thoughts please?
I'm running this on Ubuntu 11.10. Qgis version information as follows:
QGIS version
1.8.0-Lisboa
QGIS code revision
exported
Compiled against Qt
4.7.4
Running against Qt
4.7.4
Compiled against GDAL/OGR
1.9.2
Running against GDAL/OGR
1.9.2
GEOS Version
3.3.3
PostgreSQL Client Version
9.1.6
SpatiaLite Version
2.4.0
QWT Version
5.2.2
Chris Crook
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
