[Qgis-developer] Plugin layer and labelling
Martin Dobias
wonder.sk at gmail.com
Sun Jan 27 13:20:48 PST 2013
Hi Chris
On Sun, Jan 27, 2013 at 8:41 PM, Chris Crook <ccrook at linz.govt.nz> wrote:
> I'm updating a plugin to use a plugin layer to display a scale box, and I have a problem with labelling from other layers appearing on top of my plugin layer.
> I'm using a plugin layer so that the scale box will appear on the map when it is printed. It basically draws a filled rectangle and puts some text in it. The problem I have is that labelling from layers underneath the scale box layer end up plotting on top of it.
> Is there a simple way of ensuring that the box appears on top of the labelling. I'm wondering about drawing the rectangle as a label itself with some sort of custom labelling, but that looks like a lot more work :-(
I think you have these options:
- hook to QgsMapCanvas::renderComplete(QPainter*) signal and draw the
scale box in your slot
- implement a QgsMapCanvasItem that would render scale bar
By the way, there is already scale bar functionality (used to be a
plugin, now in menu View > Decorations > Scale Bar). The logic is in
QgsDecorationScaleBar class (in src/app/ dir).
Regards
Martin
