[Qgis-developer] Labeling: data-defined fields shifted after new vector API?
Régis Haubourg
regis.haubourg at eau-adour-garonne.fr
Mon Jan 28 05:17:51 PST 2013
martin Dobias wrote
> I have briefly looked into the code and it seems that new labeling
>> stores data-defined attributes by index instead of name. If so,
>> that's
>> the source of the problem and it should be changed to read/write
>> names
Hi all,
+1 for switching storage of data defined fields with names and not indexes.
It was a limit I previously pointed and this is really weak if data field
order change. But we need retrocompatibility with old projects. Does that
sounds possible?
régis
View this message in context: http://osgeo-org.1560.n6.nabble.com/Labeling-data-defined-fields-shifted-after-new-vector-API-tp5030238p5030276.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
