[Qgis-developer] State of QGIS WFS provider
Jeremy Palmer
JPalmer at linz.govt.nz
Thu Jan 31 13:17:17 PST 2013
Would also be great to be able to limit the functions and operators that are available in the expression dialog as well.
> -----Original Message-----
> From: Marco Hugentobler [mailto:marco.hugentobler at sourcepole.ch]
> Sent: Friday, 1 February 2013 9:52 a.m.
> To: Jeremy Palmer
> Subject: Re: State of QGIS WFS provider
> Hi Jeremy
> >Thanks for the comments. So I guess it's time to improve the
> current driver then.
> I'm glad you intend to work on the WFS provider (e.g. the
> filter sort model you mentioned would be a very usefull
> addition to the WFS dialog).
> >What I was referring to was the transformation from the QGIS query
> >expression to OGC XML filter which currently has >limitations
> That's true, there are certainly many things to improve here.
> One difficulty is that WFS does not standardize the filter
> function names.
> This problem might be easier to solve now that there is the
> possibility of declaring custom expression functions
> (http://woostuff.wordpress.com/2012/11/10/user-defined-express
> ion-functions-for-qgis/).
> Before that, it was somehow limited to the minimum default
> set of filter operations.
> cheers,
> Marco
> Am 31.01.2013 21:32, schrieb Jeremy Palmer:
> > Hi Marco,
> the current driver then.
> >> This is not a general limitation of the WFS provider.
> There is the possibility of writing the filter xml into the
> filter dialog as a string if needed. I know, it is not > very
> comfortable. But does the OGR driver come with a better GUI?
> > The OGR driver does not come with a better GUI. What I was
> expression to OGC XML filter which currently has limitations.
> > Cheers,
> > Jeremy
> > This message contains information, which is confidential
> and may be subject to legal privilege. If you are not the
> intended recipient, you must not peruse, use, disseminate,
> distribute or copy this message. If you have received this
> message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original
> message. LINZ accepts no responsibility for changes to this
> email, or for any attachments, after its transmission from
> LINZ. Thank You.
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions Weberstrasse 5,
> CH-8004 Zürich, Switzerland marco.hugentobler at sourcepole.ch
> http://www.sourcepole.ch Technical Advisor QGIS Project
> Steering Committee
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
