[Qgis-developer] Labeling: data-defined fields shifted after new vector API?
Marco Hugentobler marco.hugentobler at sourcepole.ch
Thu Jan 31 23:11:57 PST 2013
Hi Larry
 >So, is anyone working on this? I can devote some time this coming
weekend. Pretty important to fix this, then make it compatible with <
2.0 projects.
Thanks for looking into this .+1
 >Similarly, data defined properties are only a 1-to-1 relationship
(currently property-to-field index), with no defined relationship
between themselves, the QgsPalLayerSettings (if any) to override, the
 >associated QgsField, any defined QgsExpression, or any assigned
'buddy' gui elements. Nathan suggested a data binding class that could
possibly be inherited by gui classes to make utilizing data >defined
overrides (not just for labeling) within the app easier and more
abstracted. I think it is worth pursuing.
Sounds interesting to use expressions for data defined properties and to
have a generic class for it (e.g. also for data defined symbology, etc.).
Regards,
Marco
On 31.01.2013 02:42, Larry Shaffer wrote:
> Hi,
> On Mon, Jan 28, 2013 at 6:17 AM, Régis Haubourg
> <regis.haubourg at eau-adour-garonne.fr
> <mailto:regis.haubourg at eau-adour-garonne.fr>> wrote:
>     martin Dobias wrote
>     > I have briefly looked into the code and it seems that new labeling
>     >> stores data-defined attributes by index instead of name. If so,
>     >> that's
>     >> the source of the problem and it should be changed to read/write
>     >> names
>     Hi all,
>     +1 for switching storage of data defined fields with names and not
>     indexes.
>     It was a limit I previously pointed and this is really weak if
>     data field
>     order change. But we need retrocompatibility with old projects.
>      Does that
>     sounds possible?
>     régis
> 2.0 projects.
> possibly be inherited by gui classes to make utilizing data defined
> On another note (and yet a bunch more refactoring), most of the
> QgsPalLayerSettings are directly accessed public properties. These
> should probably be switched over to some form of container object
> (QMap?) no?
> Regards,
> Larry
>     View this message in context:
>     http://osgeo-org.1560.n6.nabble.com/Labeling-data-defined-fields-shifted-after-new-vector-API-tp5030238p5030276.html
>     Sent from the Quantum GIS - Developer mailing list archive at
>     Nabble.com.
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130201/87ea1db3/attachment-0001.html>
