[Qgis-developer] [QGIS-Server] ComposerMap as overviewFrameMap in GetPrint ?
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Jul 1 08:53:30 PDT 2013
 >* fixed extent
I don't know if this is always true. Sometimes the overview map is only
zoomed out a bit (e.g. QGIS map canvas overview map is not necessarily
zoomed to full extent, it can also move).
 >Could we imagine a way to identify overview map in composer ?
It would be straightforward to add an attribute to the
GetProjectSettings xml document. Then the client could set the overview
extent.
Regards,
Marco
On 01.07.2013 17:45, rldhont wrote:
> Hi Marco,
> The way I understand overview map is :
> * fixed extent
> * fixed layers
> * fixed scale
> But it's true that client can specified some informations.
> Regards,
> René-Luc
> Le 01/07/2013 17:40, Marco Hugentobler a écrit :
>> Hi René-Luc
>> Why do you want the overview frame map be removed from capabilities?
>> In a GetPrint request, the extent of all maps is undefined unless
>> specified from the client. How would you set the extent of the
>> overview map if not given by the client (fixed zoom-out ratio?)
>> Regards,
>> Marco
>> On 01.07.2013 17:01, rldhont wrote:
>>> Hi Marco,
>>> I have created a project with a composer with 2 maps and one as
>>> overviewFrameMap.
>>> Do you think this one has to be in the WMS Capabilities ?
>>> Do we can exclude this one form WMS Capabilities ?
>>> Regards,
>>> René-Luc
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
