[Qgis-developer] Unclear errors in PostGIS layer
Sandro Santilli
strk at keybit.net
Tue Jul 2 07:26:34 PDT 2013
On Fri, Jun 28, 2013 at 03:57:36PM +0200, Jürgen E. Fischer wrote:
> Hi Paolo,
> On Fri, 28. Jun 2013 at 15:50:42 +0200, Paolo Cavallini wrote:
> > AFAIR, the same layer was loaded by qgis 1.8: Matthias, could you confirm?
> > All the best.
> Using the same version of PostGIS / GEOS ?
> I suppose it's the && operator (bounding box intersection) and/or
> (st_)intersects function that causes this (on certain invalid geometries). And
> 1.8 would also trigger that.
Only the st_intersects function can trigger IllegalArgumentException
(it is a GEOS exception). The && operator is immune.
--strk;
