[Qgis-developer] SEXTANTE adaptation to new SAGA version
Victor Olaya volayaf at gmail.com
Thu Jul 4 11:37:22 PDT 2013
Hi all
SAGA 2.1.0 has just been released. The current version of SEXTANTE in
master has been now adapted to work with SAGA 2.1.0, and raster
algorithms will not work with any other version. Please, update your
SAGA executables if using the latest master version, since now 2.1.0
is the target version.
The only algorithm adapted so far is the raster export one, which, for
SEXTANTE, was the most important one that had been modified, since it
blocks all other raster algorithms. Other algorithms might have
changed, but they are not adapted yet. If you find something that was
working before and now it doesn't, please report. Also, if there are
new algorithms, feel free to suggest them to be added to SEXTANTE as
well, describing their syntax, if possible, to help us do it.
Windows users, please notice that the Osgeo4W installer still ships
with SAGA 2.0.8, so you will need to install SAGA 2.1.0 manually and
change the SAGA path in SEXTANTE. This will be updated soon, so it's
just a temporary issue
Thanks for your help
Victor
