[Qgis-developer] CyberTracker integration
Antonio Locandro antoniolocandro at hotmail.com
Sun Jul 7 08:53:40 PDT 2013
Hi Justin
I think your project seems a little bit similar to http://fulcrumapp.com/   http://fulcrumapp.com/features/  for field data collection, maybe just missing the part for people who can read or write
What they do is capture data using custom forms on the field and then you sync over the internet on the cloud, once on a computer you can export the data to use with GIS software and create PDF reports
Probably a similar approach?
Antonio Locandro
To: madmanwoo at gmail.com
Date: Sat, 6 Jul 2013 23:07:25 -0700
CC: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] CyberTracker integration
That’s true, I missed the concept of a form in the description on the site.  My interest is in a rich, user friendly data capture experience, especially for cases where the field user is not a QGIS user and may not be able to read or write. Our studies indicate that this is also a more efficient way to capture data for literate users. Over the years we’ve rolled our own mini-GIS for the desktop, but the scalability of this approach is clearly limited. Since we’re a non-profit and in the process of opening our code, it makes sense to leverage an existing system. Of the solutions I have investigated, QGIS seems most aligned at the technical level. We do bring some interesting work to the table. Our client supports Windows Mobile and Android and has a large library of customizable UI components which can capture many different data types, including images and sound. There is also support for timer tracks and a field map. I’m pretty new to the Open Source community, so apologies if this is off. I’m probably going about this all wrong. Cheers,-Justin From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
Sent: Saturday, July 6, 2013 10:24 PM
To: Justin Steventon
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] CyberTracker integration My project isn't about putting QGIS onto PDA.  QGIS doesn't run on PDAs and I doubt it ever will. QMap is meant to be a field collection version of QGIS. - Nathan On Sun, Jul 7, 2013 at 3:13 PM, Justin Steventon <justin at steventon.com> wrote:Thanks Jürgen, I see Nathan’s project is really about putting a stripped down version of QGIS onto a PDA. Nevertheless, it’s impressive. CyberTracker is designed more as a data capture conduit – highly customizable UI (via XML) that can be used even by low-literate folks. Integration with QGIS would be great. If anyone is interested in a collaboration, please let me know. Cheers,-Justin
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130707/869ee988/attachment-0001.html>
