[Qgis-developer] "roughly" ported RemoteDebug plugin to 2.0
Pirmin Kalberer pi_ml at sourcepole.com
Mon Jul 8 03:08:35 PDT 2013
Hi Gino,
I missed Matthias' pull request, because it was buried in too many others. But
I promise to merge your pull request within days ;-)
Regards
Pirmin
Am Montag, 8. Juli 2013, 09.47:44 schrieb Gino Pirelli:
> that was the "roughly" :)
> ok, modified str and pulled
> thank you Luigi Pirelli (luigi.pirelli at faunalia.it)
> On 6 July 2013 11:08, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> > Hi Gino,
> > I already had a pull request for the same, but your branch looks much
> > more complete.
> > So I will happily dismiss mine, once you issued a pull request for
> > yours.
> > Just a sidenote: There is no need to convert a value to a type /str/
> > and then to a type /unicode/ a simple unicode(value) instead of
> > unicode(str(value)) is fine.
> > Looking forward to having an updated version in the repo.
> > Matthias
> > On Fre 05 Jul 2013 18:34:30 CEST, Gino Pirelli wrote:
> >> Hi,
> >> to support my porting work of qgis's plugins, I found really useful
> >> the RemoteDebug plugin developed by Pirmin Kalberer of SourcePole:
> >> I roughly ported it without good testing... but it seems to work.
> >> you can find the fork here: https://github.com/luipir/qgis-remote-debug
> >> and some instruction to set it up.
> >> generally the plugin hang up qgis if it's not capable to communicate
> >> with the pydev debug server...
> >> I hope it could be useful to speed-up plugin porting.
> >> ciao Luigi Pirelli (luigi.pirelli at faunalia.it)
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
