[Qgis-developer] [Python] splitGeometry
    Denis Rouzaud
    denis.rouzaud at gmail.com
    Tue Jul  9 04:45:02 PDT 2013
Hi Bernard,
If I remember well, when you do myGeom.splitGeometry, it returns the
splitted geometry which is removed from myGeom.
So basically, you do have both parts.
Cheers,
Denis
On 07/09/2013 01:15 PM, Bernhard Ströbl wrote:
> Hi,
> I am trying to split a geometry (polygon) with a line, the line is
> straight and crossing the polygon's boundary exactly twice; here is my
> code:
> result,  newGeometries,  topoTestPoints =
> myGeometry.splitGeometry(splitterPList, True)
> the result is 0 (OK) but newGeometries contains only _one_ polygon. I
> was under the impression that newGeometries would contain _all_
> polygons resulting from the split operation, i.e. the two halves at
> each side of the line.
> If this is the intended behaviour I think I can make a workaround with
> myGeometry.difference(newGeometries[0]), if it is not I will file a
> ticket.
> Bernhard
> __________ Information from ESET Mail Security, version of virus
> signature database 8544 (20130709) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-developer mailing list
