[Qgis-developer] Dbmanager - import several shapefiles into a single postgis layer (append)
kimaidou
kimaidou at gmail.com
Tue Jul 9 05:23:13 PDT 2013
Hi all
I usually use ogr2ogr whenever I want to load several shapefile in the same
PostGIS table. I have recently seen that the import tool has an option "Add
data to a layer" in the Action groupbox. But I cannot use it since it
remains greyed out whatever the options I choose (selection a schema then
an existing table in the comboboxes).
Is this feature already working or should I stay with ogr2ogr --append for
a while ?
Thanks in advance
Michael
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130709/e070726b/attachment.html>
