[Qgis-developer] qgis-webclient - sample data > 200M
Otto Dassau
dassau at gbd-consult.de
Wed Jul 10 03:30:20 PDT 2013
Hi Andreas,
for 50M to 100M you get a warning, but the HYP_50M_SR_W.tif is 166.94 MB and
that's too much. For both files I resampled output files from 0.03 to 0.08 degree
pixel resolution. That is 4500 x 2250 instead of 10800, 5400 pixel. Still
sufficient I think.
Both would now be below 50M of size. Is that ok? Then I would commit the
changes.
Regards
Otto
Am Wed, 10 Jul 2013 12:09:47 +0200 schrieb Andreas Neumann
<a.neumann at carto.net>:
> Hi Otto,
> Thank you for pointing this out. Isn't this just a warning?
> If you have a good test project with smaller data to share I am happy to
> replace it with a smaller project.
> I just did not have the time to work on the sample project.
> Anyway - the file could be checked out by hand or it can just be ignored.
> Andreas
> Am 10.07.2013 11:49, schrieb Otto Dassau:
> > Hi,
> > I just wanted to update my fork of the qgis-web-client from master and
> > found following error message:
> > Total 64 (delta 45), reused 0 (delta 0)
> > remote: Error code: 5e0226a6eeb7f2d80768c4e7996297dc
> > remote: warning: Error GH413: Large files detected.
> > remote: warning: See http://git.io/iEPt8g for more information.
> > remote: warning: File data/SR_50M.tif is 55.70 MB; this is larger than
> > GitHub's recommended maximum file size of 50 MB remote: error: File
> > data/HYP_50M_SR_W.tif is 166.94 MB; this exceeds GitHub's file size
> > limit of 100 MB
> > Can I tell github to change the accepted file size or would it be
> > possible to use smaller test data?
> > 167M - HYP_50M_SR_W.tif
> > 56M - SR_50M.tif
> > Regards
> > Otto
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support and analysis
Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
Community Advisor - QGIS Project Steering Committee
