[Qgis-developer] qgis-webclient - sample data > 200M
Andreas Neumann
a.neumann at carto.net
Wed Jul 10 04:25:35 PDT 2013
Hi Otto,
Yes - please go ahead.
Thanks,
Andreas
Am 10.07.2013 13:07, schrieb Otto Dassau:
> Hi,
> thanks for the link. Here is the content in short:
> "GitHub warns you when you push a file larger than 50 MB. We'll reject pushes
> containing files larger than 100 MB. We do this for a few reasons."
> To fix the problem, you'll first want to remove the large file from git:
> # Stage our giant file for removal, but leave it on disk
> git rm --cached giant_file
> # Amend the previous commit with your change
> # Simply making a new commit won't work, as you need to remove the file from
> # the # unpushed history as well
> git commit --amend -CHEAD
> # Push our rewritten, smaller commit
> git push
> I can do that and apply the smaller, resampled files, if that's ok.
> Regards
> Otto
> Am Wed, 10 Jul 2013 12:50:45 +0200
> schrieb Tim Sutton <lists at linfiniti.com>:
>> Hi
>> I know gh recently reduced their maximum hosted file size - see
>> https://help.github.com/articles/working-with-large-files
>> Regards
>> Tim
>> On Wed, Jul 10, 2013 at 12:30 PM, Otto Dassau <dassau at gbd-consult.de>
>> wrote:
>>> Hi Andreas,
>>> for 50M to 100M you get a warning, but the HYP_50M_SR_W.tif is 166.94 MB
>>> and
>>> that's too much. For both files I resampled output files from 0.03 to
>>> 0.08 degree
>>> pixel resolution. That is 4500 x 2250 instead of 10800, 5400 pixel. Still
>>> sufficient I think.
>>> Both would now be below 50M of size. Is that ok? Then I would commit the
>>> changes.
>>> Regards
>>> Otto
>>> Am Wed, 10 Jul 2013 12:09:47 +0200 schrieb Andreas Neumann
>>> <a.neumann at carto.net>:
>>>> Hi Otto,
>>>> Thank you for pointing this out. Isn't this just a warning?
>>>> If you have a good test project with smaller data to share I am happy
>>>> to replace it with a smaller project.
>>>> I just did not have the time to work on the sample project.
>>>> Anyway - the file could be checked out by hand or it can just be
>>>> ignored.
>>>> Andreas
>>>> Am 10.07.2013 11:49, schrieb Otto Dassau:
>>>>> Hi,
>>>>> I just wanted to update my fork of the qgis-web-client from master
>>>>> and found following error message:
>>>>> Total 64 (delta 45), reused 0 (delta 0)
>>>>> remote: Error code: 5e0226a6eeb7f2d80768c4e7996297dc
>>>>> remote: warning: Error GH413: Large files detected.
>>>>> remote: warning: See http://git.io/iEPt8g for more information.
>>>>> remote: warning: File data/SR_50M.tif is 55.70 MB; this is larger
>>>>> than GitHub's recommended maximum file size of 50 MB remote: error:
>>>>> File data/HYP_50M_SR_W.tif is 166.94 MB; this exceeds GitHub's file
>>>>> size limit of 100 MB
>>>>> Can I tell github to change the accepted file size or would it be
>>>>> possible to use smaller test data?
>>>>> 167M - HYP_50M_SR_W.tif
>>>>> 56M - SR_50M.tif
>>>>> Regards
>>>>> Otto
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Geoinformatik Büro Dassau - http://www.gbd-consult.de
>>> FOSSGIS consulting , training , support and analysis
>>> Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
>>> Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
>>> Community Advisor - QGIS Project Steering Committee
