[Qgis-developer] Qgis-developer Digest, Vol 93, Issue 21
Victor Olaya
volayaf at gmail.com
Wed Jul 10 11:31:40 PDT 2013
Please, if you can make a list of those modules that have changed and
now do not work, it will be of great help. I planned to do a diff with
the module description that SAGA produces...but the output format has
changed, so this is not a good solution :-(
Thanks!
2013/7/10 Giovanni Manghi <giovanni.manghi at faunalia.pt>:
> Hi Victor,
> On Wed, Jul 10, 2013 at 7:11 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> Hey Giovanni, when you say "any" raster module...it means those two
>> ones only? supervised classification has changed in SAGA 2.1, so it
>> shouldn't work, and split rgb is a very special module, not actually a
>> SAGA one, but one that relies on some SAGA funcitonality...
>> Do you have problems with other algorithms? I just tested some
>> geomorphoometry ones and they were working fine.
> you are right, I was too fast saying "any", anyway I have issue with a
> few modules I tested (like tri, tpi, vrm) and not with others (slope,
> aspect, curvature). It seems that others do not have issues also with
> OTB, so maybe it is a local issue, but I don't know what it can be.
> cheers!
