[Qgis-developer] Toolbar and Panel defaults
Larry Shaffer larrys at dakotacarto.com
Wed Jul 10 15:49:48 PDT 2013
H Pirmin,
On Wed, Jul 10, 2013 at 3:29 PM, Pirmin Kalberer <pi_ml at sourcepole.com>wrote:
> Hi Jürgen,
> Am Mittwoch, 10. Juli 2013, 08.38:38 schrieb Jürgen E. Fischer:
> > On Tue, 09. Jul 2013 at 22:55:18 +0200, Pirmin Kalberer wrote:
> > > Toolbars:
> > > -Turn off Advanced Digitizing
> > > -Move Label to second row
> > > Panels:
> > > -Turn on Layer order and Browser in a tabbed view with Layers
> > > Print composer:
> > > -Place all toolbars in one row
> > In case anyone missed it:  scripts/mkuidefaults.py produces
> > src/app/ui_defaults.h from the current settings.
> Didn't know that. Updated the script to support composer UI defaults.
Couple of other ideas comments, too:
* Currently there are no side toolbars by default. Many apps utilize the
left side toolbar for critical tools. To me, such tools in a GIS app are
the canvas navigation tools. So whenever I to an initial setup of QGIS, I
always put the Map Navigation toolbar on the left.
* Similarly, I always place the Plugins toolbar on the right side. There is
currently a bug that sets that toolbar to not be shown on a default install
(that should be fixed).
I would like to hear feedback on those two suggestions for default side
toolbars. Following your suggestions (and mine), the default window would
look similar to this (on Mac) [0].
+1 for removing Advanced Digitizing toolbar as a default, as all of the
functions are available in the Edit menu already. If needed, the user can
show that toolbar.
Another major layout issue is what the layout looks like after turning on
all core plugins [1]. Then, what it looks like when all those plugin
toolbars are shown [2]. This needs some work.
[0] http://drive.dakotacarto.com/qgis/qgis_default.png
[1]
http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_no-extra-toolbars.png
[2]
http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_with-toolbars.png
Regards,
Larry
> > So updating it should be easy, once it's decides what should be the
> default.
> > Not sure if the data contains pixel coordinates and if the screen
> resolution
> > might therefore be an issue...
> Let's try: https://github.com/qgis/Quantum-GIS/pull/710
> Pirmin
> Pirmin Kalberer
> Sourcepole  -  Linux & Open Source Solutions
> http://www.sourcepole.com
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130710/eb1a1a05/attachment.html>
