[Qgis-developer] Centos Raster Anomalies
Hillers Heather
Heather.Hillers at erftverband.de
Fri Jul 12 00:54:39 PDT 2013
Hello,
I have built qgis 1.8 final release from source on Centos6. When I run make check, I get failures in qgis_rasterlayertest and qgis_rendererstest. These failures are the result of raster anomalies that do not match the expected raster anomalies stored in testdata. The raster anomalies are in many cases similar too (but a bit worse than) the expected windows anomalies. The anomalies are as follows:
I added these raster anomalies to tests/testdata/control_images/[test case], and that did eliminate the unittest failures as a result of anomalies not matching any expected anomalies. However, my unittests still fail after the anomaly match as a result of bandStatistics
QDEBUG : TestQgsRasterLayer::landsatBasic875Qml() Expected size: 120w x 120h
QDEBUG : TestQgsRasterLayer::landsatBasic875Qml() Actual size: 120w x 120h
QDEBUG : TestQgsRasterLayer::landsatBasic875Qml() 9482/14400 pixels mismatched
QDEBUG : TestQgsRasterLayer::landsatBasic875Qml() "<DartMeasurement name="Mismatch Count " type="numeric/integer">9482/14400</DartMeasurement>"
QDEBUG : TestQgsRasterLayer::landsatBasic875Qml() "<DartMeasurement name="Anomoly check" type="text/text">Checking if anomaly centos_landsat875_anomaly.png (hash fd5a62c1938dbadc2652e22c587c81e5) matches /tmp//landsat_875_result_diff.png (hash fd5a62c1938dbadc2652e22c587c81e5)</DartMeasurement>"
PASS : TestQgsRasterLayer::landsatBasic875Qml()
PASS : TestQgsRasterLayer::checkDimensions()
FAIL! : TestQgsRasterLayer::checkStats() 'mpRasterLayer->bandStatistics( 1 ).mean == 4.5' returned FALSE. ()
Loc: [/pse/edv/hil/src/qgis/18release/qgis-1.8.0/tests/src/core/testqgsrasterlayer.cpp(177)]
When I ran qgis_rasterlayertest through gdb, this mean value was found to be 4.
Qgis is linking yum installed libpng 1.2.49.
1. Are the anomalies a feature of the system, and just need to be added to testdata, or are they manifestations of a bug?
2. What can I do about the bandStatistics error? Is this going to cause bad behavior in qgis, or is only going to effect image quality?
3. Might this be coming from a library dependency?
Thanks,
MonsterMushroom
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130712/fd19db83/attachment.html>
