[Qgis-developer] Splash screen for 2.0
Tim Sutton
lists at linfiniti.com
Mon Jul 15 04:51:25 PDT 2013
Hi
Can you make a high res one? Did you use the gimp to make it? See the
master version in
https://github.com/qgis/Quantum-GIS/blob/master/images/splash/splash.xcf.bz2
Basically if you make a replacement for that we can make the 600x287
reduced version from that. Also note that you will need to put a light
stripe at the bottom for the load update messages to show clearly against
(see again above master image).
Thanks
Tim
On Mon, Jul 15, 2013 at 1:38 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi,
> I agree - the text could be more legible.
> I would propose to lighten the background map a bit to make the text
> more legible. I also changed the stroke-width of the version text a bit
> to make it more legible.
> See
> http://www.carto.net/neumann/temp/qgis_splashscreen_v2.png
> compared to the old version
> http://www.carto.net/neumann/temp/qgis_splashscreen.png
> Andreas
> Am 15.07.2013 12:16, schrieb Sandro Santilli:
> > On Mon, Jul 15, 2013 at 12:09:11PM +0200, Andreas Neumann wrote:
> >> Hi,
> >> Here is my try for a splash-screen:
> > There's not enough contrast between the background and
> > the wording, making it hard to read "QGIS" and harder to
> > read the version and name. I like the "water effect" :)
> > --strk;
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130715/f5e09a68/attachment.html>
