[Qgis-developer] [Qgis-user] [Plugin presentation] LayerCombination
Robin Cura
robin.cura at gmail.com
Wed Jul 17 02:02:41 PDT 2013
Thanks a lot for this plugin Olivier, this will be extremely usefull for
managing big projects.
May I suggest an enhancement ?
I think it would also be really usefull to save the geographic extent of
the layers combinations too.
This would enhance the spatial bookmarks, allowing the user to create real
"views" for a big project, and thus would simplify the process of map
making (in the composer) when dealing with multiple localities (sort of a
simplified Atlas composer).
What do you think of this ?
Anyway, thanks again for this work,
My 2 cents,
Robin
2013/7/17 kimaidou <kimaidou at gmail.com>
> This is huge ! Thanks for this plugin. I think this should definitely be
> added as a core plugin (in 2.1) if other agree, of course
> Michael
> 2013/7/17 Stott James <fmrojst at fylkesmannen.no>
>> Man I wish this had existed about a year and a half ago. Especially the
>> fact that it integrates into the composers too. I have always felt that was
>> something that was needed – an easy way to edit the locked layers in a
>> composer map – hence why I wrote a plugin for it.****
>> Think I may well not bother update the locked layers editor plugin to 2.0
>> seeing as you have made this. This is much better.****
>> James****
>> *Fra:* qgis-user-bounces at lists.osgeo.org [mailto:
>> qgis-user-bounces at lists.osgeo.org] *På vegne av* Lene Fischer
>> *Sendt:* 17. juli 2013 04:41
>> *Til:* Olivier Dalang
>> *Kopi:* qgis-user; qgis-developer at lists.osgeo.org
>> *Emne:* Re: [Qgis-user] [Plugin presentation] LayerCombination****
>> Wauuh****
>> What a plugin. Can't wait to use it. My studens work on big projects with
>> many layers from differe nt timeperiods. This will help !****
>> Good idea with the small video.****
>> Regards****
>> Lene Fischer****
>> Sendt fra min iPad****
>> Den 17/07/2013 kl. 01.51 skrev "Olivier Dalang" <olivier.dalang at gmail.com
>> Dear Mailing list, ****
>> I've been working on a python plugin called "Layer Combinations", which
>> I'd love to release as stable for QGIS 2.0 (it's still flagged as
>> experimental).****
>> Since it's a workflow enhancement plugin, I thought it could be of some
>> interest to most of you. If so, I invite you to try the latest version
>> (0.8, requires QGIS nightly/master), and report any bugs or ideas on the
>> tracker :****
>> https://github.com/olivierdalang/layerCombinations****
>> You'll find a small explanation of the plugin below, and a video trailer
>> here :****
>> https://vimeo.com/70446444****
>> Thanks for your attention !****
>> Olivier****
>> ## LayerCombinations##****
>> It allows to store the visibility and the folding state of the layers in
>> the legend in so called "combinations".****
>> Those combination can then be restored, allowing to switch back and forth
>> complex setups.****
>> The combinations can also be applied to composer maps. The link is
>> dynamic, which means that if the combination is updated, the composer map
>> will automatically reflect the modifications.****
>> I find it very handy for big projects with many layers and several print
>> composers.****
>> Hope you like it !****
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user****
> Qgis-developer mailing list
Robin Cura
Ingénieur d'Étude à l'UMR Géographie-cités <http://www.parisgeo.cnrs.fr>
ANR TransMonDyn <http://www.transmondyn.parisgeo.cnrs.fr>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130717/5d968597/attachment.html>
