[Qgis-developer] New API: get attribute values from a PostGIS layer
Stéphane Henriod s at henriod.info
Thu Jul 18 12:42:36 PDT 2013
Thanks Nathan,
this has indeed solved the problem.
I just updated Qgis on my Ubuntu but apparently the nightly builds haven't
taken your change into account yet. I'll give it another try in a few days
Cheers
Stéphane
"Le mot progrès n'aura aucun sens tant qu'il y aura des enfants malheureux"
-- Albert Einstein
"A journey does not need reasons. Before long, it proves to be reason
enough in itself. One thinks that one is going to make a journey, yet soon
it is the journey that makes or unmakes you." -- Nicolas Bouvier
Photos de voyages, photos de montagne: http://www.henriod.info
On Thu, Jul 18, 2013 at 12:14 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
> You will need to get the nightly builds I'm not sure what time they are
> done for Ubuntu, but If you would like you can add this code (before any
> PyQt4 imports) into your code in the meantime:
> import sip
> try:
>     apis = ["QDate", "QDateTime", "QString", "QTextStream", "QTime",
> "QUrl", "QVariant"]
>      for api in apis:
>         sip.setapi(api, 2)
> except ValueError:
>     # API has already been set so we can't set it again.
>     pass
> That will set the API version so you don't need to update just yet.
> - Nathan
> On Thu, Jul 18, 2013 at 8:10 AM, Stéphane Henriod <stephanebek at gmail.com>wrote:
>> Thanks a lot for your answer, I will try tomorrow.
>> How can I check if my installed version is already taking your change
>> into account?
>> Cheers
>> Stéphane
>> Le 18 juil. 2013 à 00:05, Nathan Woodrow <madmanwoo at gmail.com> a écrit :
>>  Hey Stephane,
>> This is because your standalone script doesn't use the new SIP API.  I
>> pushed a change last night so that now importing qgis will set the API to
>> version to.  All you need to do is make sure you import it first before any
>> of the PyQt4 modules are.
>> Before:
>> from PyQt4.QtCore import *
>> from qgis.core import *
>> After
>> If you import PyQt4 first it will set the API to version 1 which you
>> can't change after.
>> - Nathan
>> On Thu, Jul 18, 2013 at 5:13 AM, Stéphane Henriod <s at henriod.info> wrote:
>>> Dear all
>>> I am trying to get into the new 2.0 API and am still facing issues for
>>> very basic stuff: getting the values of the attributes out of a PostGIS
>>> layer.
>>> Basically, it works (with the almost same code) in the Qgis python
>>> console, but I don't manage to get it to work in a stand-alone script.
>>> What I have so far is a PostGIS layer, that I load with:
>>> *uri = QgsDataSourceURI()
>>>> uri.setConnection('localhost', '5432', 'db_name', 'user_name',
>>>> 'password')
>>>> uri.setDataSource('my_schema', 'my_table', 'the_geom')
>>>> my_layer = QgsVectorLayer(uri.uri(),'myhospitals','postgres')
>>> A quick test shows me that the layer has been successfully loaded:
>>> *if not my_layer.isValid():
>>>>     print "Layer failed to load!"
>>>> else:
>>>>     print "Layer loaded successfully"
>>> I would assume that
>>> *for elem in my_layer.getFeatures():*
>>>> *    print elem.attributes()*
>>> should return the attributes in a usable format but, instead, I get:
>>>> *[<PyQt4.QtCore.QVariant object at 0xad37aca4>, <PyQt4.QtCore.QVariant
>>>> object at 0xad37acdc>, None, <PyQt4.QtCore.QVariant object at 0xad37ad14>]
>>>> object at 0xad37acdc>, <PyQt4.QtCore.QVariant object at 0xad37ad14>,
>>>> <PyQt4.QtCore.QVariant object at 0xad37ad4c>]*
>>> Does anyone have an idea where the problem could lie?
>>> For those who speak French, the question is posted here as well:
>>> http://www.forumsig.org/showthread.php/37178-Nouvelle-API-r%C3%A9cup%C3%A9rer-les-valeurs-attributaires
>>> I am using Qgis 1.9.0 with Python 2.7 on Ubuntu 13.04
>>> Thanks in advance for ideas and comments...
>>> Cheers
>>> Stéphane
>>> malheureux" -- Albert Einstein
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130718/d42a6e5b/attachment.html>
