[Qgis-developer] A new plugin has been created by 3nids.
Denis Rouzaud
denis.rouzaud at gmail.com
Sun Jul 21 23:36:57 PDT 2013
Yes, exactly.
I am using DTM to calculate pipe slopes. If you have very short pipes
crossing two raster cells, you will get a wrong value, this is why I
needed to calculate interpolated values.
You can choose:
- nearest neighbor
- bi-linear using 4 cells
- bi-cubic using 16 cells (I did not notive slow down, but it requires
scipy)
Also, the plugin saved directly the values in the vector layer (instead
of creating a new shapefile).
Cheers,
Denis
On 07/22/2013 08:28 AM, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 22/07/2013 08:21, Denis Rouzaud ha scritto:
>>> Foreach point feature of the vector layer:
>>> - take the location of the point
>>> - calculate an interpolated value of a chosen band at the point location
> you mean, it is interpolating between adjacent cells? This is interesting, and I
> believe quite new.
> thanks.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> iEYEARECAAYFAlHs0QMACgkQ/NedwLUzIr7PFgCaAmrJGTeOnEkNqKN081xWgf0W
> Mg0AnA+fDaM8XcWZ/+2PKKVFVBfSp2ev
> =Subn
> -----END PGP SIGNATURE-----
