[Qgis-developer] print map series using bash shell on Ubuntu
Andreas Neumann a.neumann at carto.net
Wed Jul 24 01:31:39 PDT 2013
Hi Stefan,
QGIS 1.9x (the upcoming 2.0) has a serial print function called Atlas.
It does not work from the command line but from the GUI. It works well.
As far as I know it also comes with a Python API - so if you can invest
some time you can create your own python scripts for serial printing.
I would definitely recommend to use QGIS master/2.0 and not QGIS 1.8 for
serial printing purposes.
Andreas
Am 24.07.2013 07:27, schrieb Stefan Sylla:
> Dear QGIS-devs,
> I have a bunch of maps that I need to print. I already created
> qpt-templates for these maps using a shell script (on Ubuntu).
> Is there a way to call the printing function of QGIS from within the
> shell to print my templates e.g. to pdf or other formats?
> Thanks for any hints
> Stefan
> Qgis-developer mailing list
