[Qgis-developer] Labels on topologically wrong polygons
William Kyngesburye woklist at kyngchaos.com
Wed Jul 24 16:57:10 PDT 2013
Re-creating postgis configure is unnecessary with the release source, and I wouldn't suggest to most users to use dev sources.
If liblwgeom becomes a requirement for QGIS, I'll certainly be packaging it with QGIS, and adding instructions to INSTALL.
Additional notes:
It can be configured with GEOS also.
The default is to include raster and topology, neither of which is part of liblwgeom.  And configure will fail if it doesn't find GDAL for raster support.  So, disable both to same some compile time and configure hassle.
It probably requires a full install of Postgres.  It will find it automatically in /usr/local/pgsql if it's there, but probably fail if missing (don't want to delete mine to test).  This may be a blocker for the casual user that doesn't want to install Postgres.  Postgis needs an option to build just the library for this to be more accessible.
My adjusted configure:
./configure --with-geosconfig=/Library/Frameworks/GEOS.framework/unix/bin/geos-config \
--with-projdir=/Library/Frameworks/PROJ.framework/unix \
--with-jsondir=/Users/Shared/unix/json-c-snow \
--without-raster --without-topology
On Jul 24, 2013, at 1:55 PM, Larry Shaffer wrote:
> William, here is what I did [0]. Please let me know if there is something I am missing in the build steps that might cause issues for use in a bundled QGIS. Thanks.
> [0] http://drive.dakotacarto.com/qgis/liblwgeom.dylib-build.txt
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
