[Qgis-developer] fieldNameMap() crashes QGIS
Alexander Bruy
alexander.bruy at gmail.com
Mon Jul 29 10:15:31 PDT 2013
Hi Matthias,
many thanks, now works fine for me.
2013/7/29 Matthias Kuhn <matthias.kuhn at gmx.ch>:
> Commit 8c81032 implements this change.
> Can you please do a short check and open a bugreport if there's still a
> problem.
> Thanks,
> Matthias
> On Son 28 Jul 2013 23:27:24 CEST, Matthias Kuhn wrote:
>> Seems switching from the deprecated sipInstance... calls to sipType...
>> calls (e.g. sipConvertFromType, sipCanConvertFromType etc) solves this
>> issue. However, these are deprecated since sip 4.8. Can we switch all
>> of them or do we need to support older sip versions still? (The INSTALL
>> file states min SIP version is 4.5) I think we already do use some
>> (newer version only) sipType calls not within an #if condition, so I
>> guess somebody would have complained if this would be an issue...
>> On Son 28 Jul 2013 16:13:46 CEST, Alexander Bruy wrote:
>>> Hi all,
>>> seems calling fieldNameMap() on vector data provider crashes QGIS.
>>> To reproduce load shapefile and run in Python console next commands:
>>> l = iface.mapCanvas().currentLayer()
>>> fm = l.dataProvider().fieldNameMap()
>>> Anyone confirms? Should I file a ticket?
>>> Thanks
>> Hi Alexander,
>> Confirmed here. Seems to be an error in the MappedType code, because
>> we're using the deprecated sipConvertFromNewInstance instead of
>> sipConvertFromNewType.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
