[Qgis-developer] SIP API Update
Nathan Woodrow madmanwoo at gmail.com
Thu Jun 6 05:46:48 PDT 2013
Hey all,
Would I be able to get an update on where everyone is at with updating the
core plugins.  I have started updating the plugin installer and should have
that done tomorrow.
- Nathan
On Wed, Jun 5, 2013 at 7:09 AM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> On Tue, Jun 4, 2013 at 3:40 PM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
>> I just ran into another problem... how do you pass a list (of strings) to
>> a QT function which requires a QStringList (which is not available anymore).
>>  File
>> "/home/softdev/share/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py",
>> line 208, in getRasterFiles
>>     workDir.setNameFilters( filter )
>> TypeError: QDir.setNameFilters(QStringList): argument 1 has unexpected
>> type 'list'
> never mind... it works now.
>> On Thu, May 30, 2013 at 3:12 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>>> Hey all,
>>> I have decided to manage the SIP API update process so that we can have
>>> it done by 2.0.  This is an important update as leaving it for later will
>>> break every plugin yet again at later date which just leaves a really bad
>>> taste for people to deal with. A few plugin authors have already expressed
>>> that they would not be impressed having to do another major update again in
>>> the future. And I agree.
>>> So having said that this is the current plan:
>>> - I have created a branch with the SIP API v2 update
>>>  - Update all the core plugins in the sipapi-udate[0] branch over the
>>> next couple of days
>>> -  Merge into master
>>> I couldn't update all the core plugins myself BUT it would be a lot
>>> easier if I could call on the plugin authors to run though their own code
>>> and do the quick update.  The risk of me doing it is that I might break
>>> something and not know it.  You know your code best so the help would be
>>> greatly appreciated.
>>> I updated most of the console code and Salvatore has already cleaned the
>>> rest up for me so that is one thing out of the way.
>>> And here comes the kicker: I would like to do this as quickly as we can
>>> so to reduce the gap between master and the branch.  The sooner we merge it
>>> to master the sooner we can open it to wider testing, but I don't expect to
>>> run into any major issues when we do.
>>> If you are not aware of what benefits the SIP API update will bring here
>>> is a quick example:
>>> Before:
>>> >>> str(yourlineedit.text().toString())
>>> 'Hello World'
>>> >>> feature["column"].toInt()[0]
>>> 100
>>> After
>>> >>> yourlineedit.text()
>>> 'Hello World'
>>> >>> feature["column"]
>>> 1000
>>> It will make life for us and plugin authors a hell of a lot easier.
>>> I have put together a quick guide[1] with some examples.  It is open
>>> edit so feel free to add any notes you have. It might be good to turn it
>>> into a plugin translate guide for future plugin authors moving to 2.0.
>>> Regards,
>>> Nathan
>>> [0] https://github.com/qgis/Quantum-GIS/tree/sipapi-update
>>> [1]
>>> https://docs.google.com/document/d/1S85DMEC71AOzTkF1_EpnF0dhVb2On2EVq4E5s1EXoNM/edit?usp=sharing
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130606/41106cdc/attachment-0001.html>
