[Qgis-developer] Bug working with size in data-defined properties?
Jordi Torres jtorresfabra at gmail.com
Fri Jun 7 04:18:05 PDT 2013
Hi Marco,
You are right, it seems that slecting scale diameter does the trick. I
don't recall to change this, anyway thanks for the pointer.
Cheers.
2013/6/7 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
>  Hi
> Check if you have activated Advanced -> Size scale Field -> Scale area /
> scale diameter
> In the first case, size means actually area with data defined symbology.
> Regards,
> Marco
> On 07.06.2013 12:28, Jordi Torres wrote:
>  Hi Régis,
>  Thanks for the testing. I think it's not multiplied by a defined factor
> at all, divide by 0.2 and you still won't get the desired size.
>  Cheers.
> 2013/6/7 Régis Haubourg <regis.haubourg at eau-adour-garonne.fr>
>> Hi,Confirmed for me.
>> It looks like size is multiplid by a factor 0.2.
>> 6 value in data defined looks like 1,2 on screen. 1 look like 0,2.
>> BTW behaviour is not clear since old advanced properties (proportion /
>> rotation) have not been removed AND have a different behaviour. They do
>> not
>> use actual value, but act as a modifier of symbol size. New behaviour is
>> by
>> far better! (still lacks options to use non linear fonctions.. but it
>> still
>> is very nice)
>> Can anybody explains that newbehaviour and it interfers with data defined
>> style?
>> Régis
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Bug-working-with-size-in-data-defined-properties-tp5058657p5058663.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Jordi Torres
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
Jordi Torres
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130607/0184be29/attachment.html>
