[Qgis-developer] Can we remove old labeling from the UI
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Sun Jun 9 11:55:21 PDT 2013
Hi Borys
>I need to FAST put ANY labels to see what is in polygons.
Couldn't you just use 'around center' then? Afaik the old labeling
engine also does placement just on polygon centroid.
If the label has to be inside the polygon (horizontal and free placement
mode):
The problem here is not the collision detection. It is the calculation
of cost for the candiated positions that takes most of the time. I have
an open pull request that simplifies the approach and increases speed
(https://github.com/qgis/Quantum-GIS/pull/640). Still it is of course
slower than centroid placement, but the middle point of the label
position is guaranteed to be inside the polygon.
To improve the speed of label drawing (especially with buffer), I'm
working on a label cache (characters cached as images). But that one is
too risky for 2.0 and I still need to do various bugfixes before
publishing it.
Regards,
Marco
Am 09.06.2013 12:47, schrieb Borys Jurgiel:
> The only thing I *REALLY* miss in the new labelling is an optional FAST method
> to put labels just in poligon centroids with ommiting any expensive collision
> algorithms. When just browsing data the speed is priority, I don't need
> beautiful map, I need to FAST put ANY labels to see what is in polygons.
> Unless it's not available in the new labelling, we make a regression, removing
> one of the most fundamental features. Please correct me if I'm missed some PAL
> option that I can disable to achieve a significant boost.
> Dnia niedziela, 9 czerwca 2013 o 12:13:01 MORREALE Jean Roc napisał(a):
>> What is the status ? Are we going to keep a deprecated label tab for the
>> next 3 years ?
>> Le 26/05/2013 14:37, Nathan Woodrow a écrit :
>>> Can we finally remove the old label UI from the layer properties dialog?
>>> Could we remove it by default and just enable it for old project that
>>> have old labels defined.
>>> - Nathan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
