[Qgis-developer] Can we remove old labeling from the UI
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Sun Jun 9 11:59:32 PDT 2013
I thought there also was the target or wish making QGIS able to
read/interpret the old labels (e.g. when opening a 1.8 qgs project
file). My experiences are that this does not work. (Even using the old
label dialog in qgis-master does not work properly) Therefore IMHO the
old labeling is useless.
Marco
Am 09.06.2013 19:28, schrieb Tim Sutton:
> Hi
> I also think we should hide the old labelling dialog. I think Larry
> was working on migration logic that would allow old labels to be
> converted to new. I cant remember if he kept this back for 2.1 though.
> Assuming its not ready, we should follow Nathan's suggestion of hiding
> the old labels tab unless the project file indicates it is needed.
> PS optimisation wise couldnt we just have a 'quick' mode that draws a
> maximum of n labels pre render?
> Regards
> Tim
> On Sun, Jun 9, 2013 at 2:36 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> Marco Hugentobler is currently working on optimizing the labeling of
>> area features. Because it is feature-freeze I don't know if this will be
>> added to 2.0 or delayed for 2.1 - maybe the PSC can make a decision
>> about this.
>> Personally I would recommend to get rid of the old labeling now.
>> Andreas
>> Am 09.06.2013 12:47, schrieb Borys Jurgiel:
>>> The only thing I *REALLY* miss in the new labelling is an optional FAST method
>>> to put labels just in poligon centroids with ommiting any expensive collision
>>> algorithms. When just browsing data the speed is priority, I don't need
>>> beautiful map, I need to FAST put ANY labels to see what is in polygons.
>>> Unless it's not available in the new labelling, we make a regression, removing
>>> one of the most fundamental features. Please correct me if I'm missed some PAL
>>> option that I can disable to achieve a significant boost.
>>> Dnia niedziela, 9 czerwca 2013 o 12:13:01 MORREALE Jean Roc napisał(a):
>>>> What is the status ? Are we going to keep a deprecated label tab for the
>>>> next 3 years ?
>>>> Le 26/05/2013 14:37, Nathan Woodrow a écrit :
>>>>> Can we finally remove the old label UI from the layer properties dialog?
>>>>>   Could we remove it by default and just enable it for old project that
>>>>> have old labels defined.
>>>>> - Nathan
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
