[Qgis-developer] Plugin "category" - do we need it?
Matthias Kuhn
matthias.kuhn at gmx.ch
Tue Jun 11 09:46:53 PDT 2013
My main point is, that a category is a single entry, while a plugin can
actually place no menu entry at all to menu entries in different menus.
So it should rather be a list of menus where you find related entries
in than a single entry. Actually this does not offer the possibility to
add a fair usage description for plugins which offer a different
approach than to place an entry in a menu (e.g. add additional entries
in the layer legend context menu...).
So I would remove it to make place for a more dynamic system (e.g.
quick start text of max 300 chars) where a good recommendation for
plugin dev's exist on how to write this text.
I have absolutely no strong opinion on this. I think Paolo deals more
with users than I do.
Cheers
On Die 11 Jun 2013 18:35:17 CEST, Borys Jurgiel wrote:
> Dnia wtorek, 11 czerwca 2013 o 17:57:58 Paolo Cavallini napisał(a):
>> Il 11/06/2013 17:12, Matthias Kuhn ha scritto:
>>> +1 for removing category in favor of tags.
>>> On Die 11 Jun 2013 17:09:10 CEST, Borys Jurgiel wrote:
>>>> Among many other plugin attributes we have quite useless "category":
>>>> vector/raster/db etc.
>>>> Are there any thoughts?
>> It is sometimes difficult to find where a plugin menu is installed. I have
>> found that the category can help users (if correctly described, of
>> course).
>> All the best.
> The problem is it must be correctly set...
> So we have +1 for removing it and +1 for keeping. Well, I can keep it in the
> detail view, even stronger exposed, but I guess still in a form "Category:
> blahblah" rather than "Hopefully you may find it in the Vector menu" ;-)
> Qgis-developer mailing list
