[Qgis-developer] SIP API Update merged. Attention plugin authors
Nathan Woodrow
madmanwoo at gmail.com
Wed Jun 12 03:34:45 PDT 2013
As far as I understand.
If min = 2.0
max will default to 2.99
If min 1.8
and max 2.0 it will work in both 2.0 and 1.8
- Nathan
On Wed, Jun 12, 2013 at 8:27 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Sun, Jun 09, 2013 at 10:27:51AM +0200, Borys Jurgiel wrote:
> > Actually no breaking change happened now, there would be just MUCH more
> > switches (assuming that e.g. each formerly QString-type variable may be
> either
> > QString or unicode). So in the simplest plugins you can still use them
> and
> > make the plugin dual-API-compatible. Just remember to explicitly set both
> > qgisMinimumVersion and qgisMaximumVersion, otherwise QGIS assumes
> > qgisMaximumVersion at 1.999.
> Does this mean that 2.0+ compatible plugins will always need to set
> a qgisMaximumVersion ? Or will plugin manager be smart enough to assume
> an higher max if qgisMinimumVersion=2.0 ?
> --strk;
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130612/e0b68878/attachment.html>
