[Qgis-developer] SIP API Update merged. Attention plugin authors
Gino Pirelli
luipir at gmail.com
Thu Jun 13 15:00:15 PDT 2013
Hi I'm Luigi Pirelli
I'm porting rt_mapserver_export to the new 2.0 SIP api
I found another case where it's necessary to pay attention (and could be
added in the wiki:
http://hub.qgis.org/wiki/quantum-gis/Python_plugin_API_changes_from_18_to_20
as the case before about floats, a simple replace could create problems
because
variable.to<Type> returns a tuple (value, <check on value[true|fase]>)
so, in case in the old style plugin, the code has this (as in
rt_mapserver_export)
(returnValue, returnCheck) = variable.to<type>
doing upgrade to 2.0 as in wiki page produce
(returnValue, returnCheck) = variable # <--- generates a unique value or
exception
instead of a tuple
generate a runtime error: "ValueError: too many values to unpack"
so the wiki could show another option like this one:
before
after
returnValue = variable
returnCheck = isinstance(variable, <type>)
or
returnCheck = true
try:
except ValueError:
returnCheck = false
I didn't check for all the types
ciao Luigi Pirelli
ps: I hope my is English is enough understandable
On Sun, Jun 9, 2013 at 4:42 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Just found another case which requires special attention:
> Given a feature with myInt=5
> Old API:
> > feat['myInt'].toFloat() / 10
> > 0.5
> New API:
> > feat['myInt'] / 10
> > 0
> Better:
> > float( feat['myInt'] ) / 10
> > 0.5
> Or:
> > feat['myInt'] / 10.0
> > 0.5
> I guess that's not something we can fix in a generic way, but something
> to keep in mind when updating a plugin.
> On Son 09 Jun 2013 16:38:09 CEST, Victor Olaya wrote:
> > I find that same behaviour that Matthias confirms.
> > I guess it should be fixed, since it forces developers to add extra
> > code to handle that case, and it can be very confusing (all other
> > Qvariants are removed, except in this case...)
> > Hopefully it will be easy to fix.
> > Thanks in advance!
> > Victor
> > 2013/6/9 Nathan Woodrow <madmanwoo at gmail.com>:
> >> Ok I'll check it out and see if it can be converted.
> >> -- Nathan
> >> On Mon, Jun 10, 2013 at 12:19 AM, Matthias Kuhn <matthias.kuhn at gmx.ch>
> >> wrote:
> >>> On Son 09 Jun 2013 16:02:57 CEST, Nathan Woodrow wrote:
> >>>> Victor,
> >>>> Which code is returning a QVariant null?
> >>> feat['myAttribute']
> >>> returns QPyNullVariant for all features which have a NULL value in the
> >>> field myAttribute.
> >>> None would work for me as well. But I'm not sure, why PyQt introduced
> >>> this new type. Maybe there is a reason?
> >>> Matthias
> >>>> - Nathan
> >>>> On Mon, Jun 10, 2013 at 12:01 AM, Victor Olaya <volayaf at gmail.com
> >>>> <mailto:volayaf at gmail.com>> wrote:
> >>>> I am checking the SEXTANTE adaptation to the new SIP API, and
> >>>> everything is fine. The only "strange" thing that I found is how
> >>>> null
> >>>> values are handled when they appear in a vector layer field. It
> >>>> seems
> >>>> that, in that case, a QVariant is still returned (particularly a
> >>>> QPyNullVariant object). Wouldn't it be better to return a Python
> >>>> None
> >>>> instead, so in all cases Python values are returned?
> >>>> Cheers
> >>>> 2013/6/9 Richard Duivenvoorde <rdmailings at duif.net
> >>>> <mailto:rdmailings at duif.net>>:
> >>>> > On 09-06-13 10:47, Nathan Woodrow wrote:
> >>>> >> Technically this can be done for smaller plugins like Borys
> said.
> >>>> >> Something like:
> >>>> > I think only for VERY small plugins. In the (not so very big
> >>>> plugins) I do
> >>>> > it was already getting messy.
> >>>> > And by the why, a big thank you for all the great work and
> >>>> decisions being
> >>>> > done lately! I really think 2.0 will be great \o/
> >>>> > Richard
> >>>> > _______________________________________________
> >>>> > Qgis-developer mailing list
> >>>> > Qgis-developer at lists.osgeo.org
> >>>> <mailto:Qgis-developer at lists.osgeo.org>
> >>>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130614/dfdfc94e/attachment.html>
