[Qgis-developer] SIP API Update
Etienne Tourigny
etourigny.dev at gmail.com
Fri Jun 14 12:06:25 PDT 2013
I have done some more fixing of GdalTools.
What remains are the algorithms in the Conversion and Analysis menus - most
work left is tedious work changing QString->str and QStringList->list
help and testing would be appreciated. Any volunteers?
Etienne
On Mon, Jun 3, 2013 at 6:14 PM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> The following core plugins do not load properly:
> plugin_installer
> GdalTools
> Do the respective devs plan to fix this? I could help out a bit with
> GdalTools, but I don't know anything about the plugin_installer plugin to
> really help.
> Cheers
> Etienne
> On Thu, May 30, 2013 at 3:12 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> Hey all,
>> I have decided to manage the SIP API update process so that we can have
>> it done by 2.0. This is an important update as leaving it for later will
>> break every plugin yet again at later date which just leaves a really bad
>> taste for people to deal with. A few plugin authors have already expressed
>> that they would not be impressed having to do another major update again in
>> the future. And I agree.
>> So having said that this is the current plan:
>> - I have created a branch with the SIP API v2 update
>> - Update all the core plugins in the sipapi-udate[0] branch over the
>> next couple of days
>> - Merge into master
>> I couldn't update all the core plugins myself BUT it would be a lot
>> easier if I could call on the plugin authors to run though their own code
>> and do the quick update. The risk of me doing it is that I might break
>> something and not know it. You know your code best so the help would be
>> greatly appreciated.
>> I updated most of the console code and Salvatore has already cleaned the
>> rest up for me so that is one thing out of the way.
>> And here comes the kicker: I would like to do this as quickly as we can
>> so to reduce the gap between master and the branch. The sooner we merge it
>> to master the sooner we can open it to wider testing, but I don't expect to
>> run into any major issues when we do.
>> If you are not aware of what benefits the SIP API update will bring here
>> is a quick example:
>> Before:
>> >>> str(yourlineedit.text().toString())
>> 'Hello World'
>> >>> feature["column"].toInt()[0]
>> 100
>> After
>> >>> yourlineedit.text()
>> 'Hello World'
>> >>> feature["column"]
>> 1000
>> It will make life for us and plugin authors a hell of a lot easier.
>> I have put together a quick guide[1] with some examples. It is open edit
>> so feel free to add any notes you have. It might be good to turn it into a
>> plugin translate guide for future plugin authors moving to 2.0.
>> Regards,
>> Nathan
>> [0] https://github.com/qgis/Quantum-GIS/tree/sipapi-update
>> [1]
>> https://docs.google.com/document/d/1S85DMEC71AOzTkF1_EpnF0dhVb2On2EVq4E5s1EXoNM/edit?usp=sharing
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130614/243b5676/attachment.html>
