[Qgis-developer] Python plugin installer: cannot load from local repository when proxy is set
Andreas Neumann
a.neumann at carto.net
Mon Jun 17 08:28:04 PDT 2013
I have a problem when using a local repository when a proxy is set. It
seems that the proxy exceptions are not honored.
I created an issue:
http://hub.qgis.org/issues/8092
In the proxy tab there is a list of proxy exceptions and this seems to
be ignored.
Thank you if someone with knowledge on the Python plugin installer
could have a look at this problem.
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
