[Qgis-developer] EPSG 4326 coordinate ordering
Antonio Locandro antoniolocandro at hotmail.com
Mon Jun 17 11:12:06 PDT 2013
Hello devs
I got into a bit of problems today trying to render a GML file, I get the features in the wrong position. (https://docs.google.com/file/d/0B2WxCPuMM8hEanNmSDUyVU1JRFk/edit?usp=sharing)  image
(https://docs.google.com/file/d/0B2WxCPuMM8hEQkhDWUNmSEM5Qkk/edit?usp=sharing  ) gml file for France airports
After investigating a bit I found that
"EPSG:4326 specifically states that the coordinate order should be latitude, longitude. Many software packages still use longitude, latitude ordering" which seems to be the case for Proj4 which is used in QGIS
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs Now my question is how can I have the correct definition for EPSG 4326 to use? Should I create a custom CRS and how? Using windows
Thanks for your time
Ing. Antonio Locandro
Tegucigalpa, Honduras
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130617/89c4fe72/attachment.html>
