[Qgis-developer] Relative paths in mapserver
Alex Mandel
tech_dev at wildintellect.com
Wed Jun 19 22:31:37 PDT 2013
Shorter urls are easy with Apache using Alias (This is the same way
recommended for Mapserver too) and symlinks.
symlink your qgs documents into /maps
then add and apache alias
Alias /maps /cgi-bin/qgis_mapserv.fcgi
Now urls would be
http://server.com/maps?map=/maps/test.qgs etc...
Anyone know if you can alias the part after map= ?
Enjoy,
Alex
On 06/19/2013 10:09 PM, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 19/06/2013 22:35, Marco Hugentobler ha scritto:
>> Relative pathes _to_ the project file are currently not supported (though it is easy
>> to resolve the relative pathes). What is your use-case? Do you have several different
>> server instances on your machine?
> Thanks Marco for clarifying. So I can use only:
> qgis_mapserv.fcgi?map=/usr/lib/cgi-bin/test/test.qgs
> Right?
> Only one mapserv instance, I just liked shorter URLs.
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlHCjoAACgkQ/NedwLUzIr5ouACdHtVffQ/PVwviPiYYML90pikZ
> dKwAn3/wVZb5ViiE2Hr+8pInK6Wc082I
> =JEzE
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
