[Qgis-developer] Relative paths in mapserver
Andreas Neumann
a.neumann at carto.net
Wed Jun 19 23:37:45 PDT 2013
I agree - I don't see the use case for relative project files. In
production environment you will use Apache rewriting and for
dev-purposes it doesn't matter much if the URL is a bit longer.
Plus, as Alex said - relative to what? It is not obvious.
Andreas
On Wed, 19 Jun 2013 22:50:36 -0700, Alex Mandel wrote:
> On 06/19/2013 10:48 PM, Paolo Cavallini wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Il 20/06/2013 07:31, Alex Mandel ha scritto:
>>> Shorter urls are easy with Apache using Alias (This is the same way
>>> recommended for
>>> Mapserver too) and symlinks.
>> Thanks for the replies. Yes, I was aware of these solutions, I was
>> kind of assuming
>> it should have worked also with relative paths.
>> All the best.
>> Paolo Cavallini - Faunalia
> The problem I see with that, is relative to what? Apache web root?
> fcgi location? Seems like a lot of possible options.
> Thanks,
> Alex
> Qgis-developer mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
