[Qgis-developer] Dev plugin for master
PIERRE Sylvain sylvain.pierre at cg67.fr
Wed Jun 26 07:50:06 PDT 2013
Forget this ....
→	Sylvain PIERRE
	Ingénieur Géographe
         Adjoint au chef du service
	Direction de l’Agriculture, de l’Espace Rural et de l’Environnement
	Service Administration Générale
	Conseil Général du Bas-Rhin
	Passerelle 67
	20 rue Livio / 67000 Strasbourg
	Tél : +33 3 88 76 68 88 – mobile :
	Fax : 03 88 76 68 71
	Email : sylvain.pierre at cg67.fr
-----Message d'origine-----
De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de PIERRE Sylvain
Envoyé : mercredi 26 juin 2013 16:04
À : Borys Jurgiel; qgis-developer at lists.osgeo.org
Objet : Re: [Qgis-developer] Dev plugin for master
You're right!
Plugin is invalid no more
But I have a new problem:
Couldn't load plugin thememanager due an error when calling its classFactory() method
  File "C:/OSGeo4W/apps/qgis-dev/./python\qgis\utils.py", line 204, in startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "C:\Users\sylvain.pierre/.qgis2/python/plugins\thememanager\__init__.py", line 25, in classFactory
    return ThemeManager(iface)
TypeError: 'module' object is not callable #########################################################################
→	Sylvain PIERRE
	Ingénieur Géographe
	Passerelle 67
De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Borys Jurgiel Envoyé : mercredi 26 juin 2013 15:09 À : qgis-developer at lists.osgeo.org Objet : Re: [Qgis-developer] Dev plugin for master
Dnia środa, 26 czerwca 2013 o 14:56:11 PIERRE Sylvain napisał(a):
> Master version installed yesterday with osgeo4w apt I don’t have
> metadata.txt file, only entries in _init_.py file…
So the manager was right, you use the approach for QGIS 1.x.
Please look at the two wiki pages refered in this topic.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
