[Qgis-developer] GDAL tools not working in latest nightly builds
Giuseppe Sucameli
brush.tyler at gmail.com
Thu Jun 27 13:56:26 PDT 2013
Hi Etienne,
On Thu, Jun 27, 2013 at 10:21 PM, Etienne Tourigny
<etourigny.dev at gmail.com>wrote:
> seems to me it only happens in OSX,
it happens whether the user set paths into Settings dialog (so usually on
OSX).
> because all tools have been updated. Can you fix it and send me a patch?
I'm working on fixing it, I've already patched it and some other tools
(i.e. FillNoData, Info, Translate) that doesn't work in this moment.
Cheers.
> Etienne
> On Thu, Jun 27, 2013 at 11:22 AM, Cline, Royce L. <rcline at nd.gov> wrote:
>> They worked prior to the SIP changes. Now I am getting the following
>> QString error no matter which raster tool I try. Is anybody else seeing
>> this?
>> An error has occured while executing Python code:
>> Traceback (most recent call last):
>> File
>> "/Applications/QGIS_2.0-devJun26.app/Contents/MacOS/../Resources/python/plugins/GdalTools/GdalTools.py",
>> line 333, in doInfo
>> d = Info( self.iface )
>> File
>> "/Applications/QGIS_2.0-devJun26.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/doInfo.py",
>> line 45, in __init__
>> BasePluginWidget.__init__( self, self.iface, "gdalinfo" )
>> File
>> "/Applications/QGIS_2.0-devJun26.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/widgetPluginBase.py",
>> line 39, in __init__
>> self.base = BaseDialog( iface.mainWindow(), iface, self,
>> self.windowTitle(), commandName)
>> File
>> "/Applications/QGIS_2.0-devJun26.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/dialogBase.py",
>> line 49, in __init__
>> Utils.setProcessEnvironment(self.process)
>> File
>> "/Applications/QGIS_2.0-devJun26.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/GdalTools_utils.py",
>> line 827, in setProcessEnvironment
>> elif not QString( envval ).split( sep ).contains( val,
>> Qt.CaseInsensitive ):
>> NameError: global name 'QString' is not defined
>> Python version:
>> 2.7.2 (default, Oct 11 2012, 20:14:37)
>> [GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)]
>> QGIS version:
>> 1.9.0-Master Master, a597823
>> Royce
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130627/a75a3c7d/attachment.html>
